Re: bearing housing
What you are probably looking at at the aft end of the housing, are the hydrostatic seal rings, they are not threads. The carrier pulls through the prop shaft with a puller applied against the prop shaft. I would suggest getting a OMC shop manual to do this operation, plus what ever other maintenance you would need to do.
