Hi fellow iBoaters,
I'm looking at purchasing a 2002 Fourwinns H200. While looking it over with the owner I found that one of the hubs on the trailer has a failed bearing and he and I removed it quickly to find that the spindle has damage. It looks like the spindle is not replaceable, would you all suggest replacement? The trailer is rated at 7000lbs so i'd assume that both axles are 3500lb axels. Can I replace this axle with a standard axle I can order from my trailer supply shop? or do I need a special submersible axle?
Thanks,
Thanks,
