Re: BEARING BUDDY REMOVAL
Jack it up, spin the wheel slowly while tapping toward you on the side of the BB with a rubber mallet. It'll walk off as you tap around the perimeter of the BB, and eventually fall on the ground.<br /><br />As for your rear seal, you gotta take the hub all the way off. Most trailers have a cotter pin/single hub nut setup. You'll also want to know how to inspect and then properly repack and preload the bearings so they're properly adjusted.<br /><br />Do a Google search on "repack trailer bearings" and you'll find all kinds of walk-thru procedures with photos & the works.
