Bearing Buddy Broke Off In Hub
skydiveD30571
2007 EZ-Loader tandem axle trailer for 21ft Seaswirl 210 br
It has the EZ-Lube hubs, but I like to use a combo of that and bearing buddies. What that means is, I grease the EZ-Lube fitting to pump out the old grease until new grease comes out, remove the grease fitting and install Bearing Buddy, then give it a couple pumps to put positive pressure on the diaphragm (yes I'm extra careful to not overfill). Sure it's probably overkill but I believe I get the best of both systems this way.
Anyway, during routine maintenance yesterday I was walking off the last Bearing Buddy with a light rubber mallet like I've always done, but this one decided to snap off before it came out. Now half of the circumference of the "tapered end" is stuck in the hub, perfectly flush with the hub lip. Anybody ever break a Bearing Buddy off before? How about ideas on getting it out? There is a small gap between it and the inner surface of the hub, not enough to get pliers in, but I might be able to get the tip of a flat-blade screwdriver or a punch in there. I'm thinking if I can break it in half it will fall out since it is a tapered surface and holding itself in. There was no rust or corrosion anywhere so I don't believe it is seized in any way. It was just one of those days :mad:
oldjeep
Re: Bearing Buddy Broke Off In Hub
I guess I'd just take the hub off and drive it out with the bearing race rather than try to split a piece of stainless steel.
phillyg
.................. There is a small gap between it and the inner surface of the hub, not enough to get pliers in, but I might be able to get the tip of a flat-blade screwdriver or a punch in there............./QUOTE]
That's exactly what I would try to do.
fishrdan
Good idea, but wouldn't there be enough lip on the broken off BB, to just drive it out, and not mess with the race?
SOTW's idea is good too.
If you can see enough of the BB lip inside the hub, the small pry bar in this pry bar set may be able to work it out. Depends on how much space is between the axle stub and the BB lip.
SilverSS07
I'd try the slide hammer as mentioned. Parts stores around here loan them out free. Maybe a pilot bearing tool would open up enough to get in there...
skydiveD30571
Thanks fellas I got it out relatively easily last night. I was also incorrect...it was a full ring that broke off in the hub. Grease was hiding half of it pretty good at first. I took the hub off and worked it out slowly with light prying. Inspected the bearing and put it back together.
MH Hawker
Good i thought it would be a ring.
