RandyJ
Master Chief Petty Officer
- Jun 13, 2002
- 808
I am not very familiar with ordering cables. Overall length is something near 13' the housing is 12 ft. Should I order 13' or 12' cable? Not sure what type to order but I'm thinking it looks most like a Universal 3300 teleflex. Eventhough I'll be using it in freshwater I'd rather order the stainless steel cables. Any help out there?
This is the same old 1983 Capri 19' Cuddy cabin I've been working on. Runs great but cables are rotten...and the usual bad electrical connections. Used an old Ford relay to replace the starter slave relay. Trim was working but now it's not.. will have to figure that one out. Manifold is leaking water...thinking it has a brass plug in the bottom, any tips on that? Will I have to remove the manifold to replace it? Any quick fixes anyone knows of? Is there a way to pressure test the manifold? I'm sure hoping it's not a cracked manifold...went thru all that with mercruisers.
