Bayliner Oil Change
chicubs08
How do i change the oil on my Bayliner?
Is a 1987 Bayliner Capri Bow Rider?Engine is a 2.3LR 110h.p. 4 Cylinder ?Ford? I/O with the o.m.c cobra outdrive.
And how do i set the timing?
Dakota47
Re: Bayliner Oil Change
Ask Bondo, Thats his favorite set up.. "Bayliner/Ford/Omc" :D
bruceb58
There is a threaded fitting on the dipstick that you can attach an oil change pump to.
Coors
No questions about what is the proper oil to use?
chicubs08
i already bought the oil from my local marina. I got Mercury SAE 25W-40 oil. Is this the right oil?
Don S
Yes, that is the right oil. According to Mercruisers recommendations.
Dakota47
It will be fine.. Cheveron Delo 400 15w40 works great too.. heck wal-mart 10w30 works too..
Coors
Delo is much better than any walmart brand; it has more additives, and is designed to lube a diesel, which has a higher breakdown ratio, squared, due to the higher compression, and sulfer.
f_inscreenname
IMHO the Shell Rotella (sp?) is the best out there for a non roller motor.
Where is L/D when you need him.:D
chicubs08
i just changed my oil this morning. The old oil that i took out was dark greenish in color. It didn't even look like oil. It looked like dirty greenish water. Is this normal? My boat is running much better now. But sometimes when i accelerate and decelerate my boat will turn off.
Don S
Are you sure you didn't change the outdrive oil instead of the engine oil? Many places use Hi Performance Mercruiser gear lube (it's green) in the Cobra drives.
chicubs08
nope...I attached the hand pump where the dip stick is it has threads. How do i change the out drive oil?
BAYLINER185
You dont suppose they put gear oil in the engine oil and he just found out about it ?
maby it was good he changed the oil before he'd be making that into a BAYLINER / MERCRUSIER / MERCRUISER ALPHA ONE
BAYLINER185
Oh to change the drive oil.....I can only assume its the same as a merc drive. Im not sure if theres one or more steps involved but Ill tell you how to do it on a merc drive.
On the lower part of the drive there is a drain screw close to the top there is a vent screw. You open the drain screw then open the vent screw and the old oil will drain out. ( not sure if you have a monitor bottle on that set up, problably not )
Once the oil is al drained out you need a lube pump to pump the oil back in at that drain plug location. You pump the drive full till the oil starts to flow from the vent screw. Replace the vent screw and as fast as you can remove the pump and put the drain screw back in so you dont loose too much oil.
NOW if you have a monitor bottle after you put the vent screw back in according to the manual you keep pumping in oil till it fill the bottle to the fill mark, then remove the pump and replace the drain screw.
NOTE : 1987 models I dont beleive had a monitor bottle. I had an 84 that didnt and I dont beleive they started till much later.
Don S
BL185
If someone has an OMC drive, don't give them Mercruiser instructions.
Don't assume that everything is the same, they aren't and if he tries to fill like a Mercruiser, he has a very good chance of destroying his outdrive. And many newbe's assume (and are wrong) that an outdrive is an outdrive and what works for one will work for another.
