bayliner id numbers
chitownborn
hello iboaters, im thinking about buying a 1988 bayliner, great shape and all around real good looking boat, owner has all maintenance records etc etc the problem im having is the serial numbers on the back of the boat arent really to legible to check with the paper work and title, so my question is did bayliner mark these boats with id numbers some were else on these boats, i just wanna make sure this boat is legit before the possibility of buying. thanks don
Genonbamagirl
Re: bayliner id numbers
Well - you've done your research on the type of boat you want and this is the one?
woosterken
could you put a splash of paint on it,then wipe the paint from the area around the number ,leaveing the letters hilited?
woosterken
Ayuh,... The Only place I've ever found a Hin on Any boat is at the top starboard aft corner...
Bayliner being an entry-level boat, I doubt has 'em anyplace else...
captharv
Normally, I'd say if the HIN # is not legible, walk away from it.
Otherwise, have a cop check it out, and have him certify on paper thats its legit.
An illegible ID # will cause problems in a "safety check" stop by a law enforcement officer. The best it get is waiting an hour for teh state computer to verify the data. Worst it gets? Use your imagination
chitownborn
thanks for the responses, im gonna walk away from this one, nice boat but dont need the hassle,
