Bay manufacturing shaft extender kit, need info
hotrod53
I just found out that I have a Bay Manufacturing short to long shaft conversion kit on my motor. I also realized when I replaced the lower unit, that I have no reverse lock rod.
My kit is a #408 and I have the parts list and diagram, it shows no reverse lock rod. If this were a T/T motor, it would make no difference. Being manual, my motor is going to climb up.
Does anyone have experience with these things?
carholme
Re: Bay manufacturing shaft extender kit, need info
53;
We seem to have been through this before. If this kit is being used on your '77 Merc 500, you will see from this list that it uses a 406 kit whereas the 408 is used on the 35/40/45. The 408 is a 5" kit where the 406 is a 4" extension.
http://www.marineparts.com/partspages/accessories/acc8.htm
Could this be your problem?
Gerry
