Re: Battery wiring for 12/24 volt
There are as many different wiring schemes for 12/24 systems than there are boats. Your system is wired correctly AT THE BATTERIES but it may not be correct up front. Some additional info is needed.
1) do you have a three or four terminal trolling motor receptacle.
2) Does your boat have a 12/24/RUN/CHARGE switch on the panel next to the receptacle? If so, what are the switches and how are they labeled.
3) What make and model troller do you have.
4) Normally, if measuring voltage at the receptacle, the terminals where the red and black wire match up from the trolling motor will measure either 12 or 24 volts. Some have this as the 24 volt pair, others have that as the 12 volt pair.
5) The Orange - Black pair would then be the opposite of whatever the red - black pair measure. (If Red-Black = 24 volts, then Orange-Black = 12 volts.
If your boat does not have any switches on the receptacle panel, then the orange and red wires in the either the troller plug or receptacle are switched. Ground is ground so you cannot screw that up. If the red and orange wires on the troller plug are switched setting the switch to 24 volts would only run the motor on 12 volts which would kill the battery quickly. So break out the voltmeter and check the receptacle.
