battery will not charge
90paramedic
I have a 2005 90hp 4 stroke yamaha that will not charge the battery. I have 12.5 volts cold check and with the engine running I have the same. I replaced the battery, cleaned and tightened the connections and checked the fuses. Any suggestions?
phwrd
Re: battery will not charge
If you have the same volts at cold as you with it running, charging system isn't working. I recently had the rectifier replaced due to the same issue.
