Battery voltage question.
agallant80
I forgot to change the switch to off on the boat and I drained the battery. Did not notice until two weeks later. I took the battery home put it on the charger for a day (smart charger thing). When I took the battery off it was reading 13.3 Volts. After about a week sitting in my livingroom it reads 12.7 volts. Is the battery damaged or is it good to go?
dingbat
Re: Battery voltage question.
The 13.3 was a surface charge. The 12.7 is the charged voltage. Check it again in a couple of weeks to see if it's stabilizes. If so, your good to go
bruceb58
Get an inexpensive load tester and test it. As batteries go bad, they lose their capacity but are able to reach full charge voltage.
100 Amp 6 Volt/12 Volt Battery Load Tester
You are probably fine especially if its a deep discharge battery. Do that a couple times to a starting type battery and it will be toast though.
MH Hawker
The old cheese grater, thats one of the better ones around. In fact if its on sale I need to pick one up.
