Battery to engine
scotiany
Re: Battery to engine
Follow the lead from the starter solenoid back to the boat. That's your positive lead.
s911houston
I tried tha to hock up the pos from the battery to the starter and I grounded the groud but I was geting sparks from the battery
scotiany
The positive lead goes from the battery to the starter solenoid and then to the starter. The neg. lead grounds on the engine. I would try removing and cleaning all pos. wiring connections and the ground connection too with a wire brush. You could also possibly have a bad ignition switch.
s911houston
I tried that but the battery gives off a spark...does that mean that maybe I wired something else wrong....
Silvertip
Honorary Supreme Mariner
Accessories (radio with a clock and memory function, etc) that draw a small amount of current will cause a slight spark. If its a rather large zap you see, yes -- you have something wrong. Make sure the positive battery cable connects to the large post on the starter solenoid (not the starter). The other large post on the solenoid goes to the starter. The negative cable simply bolts to the engine block. You might try disabling all of the accessories on the boat by removing their fuses. If you still get a spark, something else is wrong.
eurolarva
Who better to answer this thread then upinsmoke. Sorry and nothing personal intended but a sparking outboard engine with upinsmoke replying makes me laugh.
scotiany
I seem to remember reading somewhere in this forum that you're not supposed to connect anything to the engine circuit. Accessories should have their own leads from the battery.
Silvertip
No problem Eurolarva, I chose that name for the very reason you commented. You got a suggestion and a laugh -- all for free. I suppose I could have used a name like "NoBlownFuses" or something similar but that's not nearly as fun as "Upinsmoke". Besides, there's nary a person on this board that hasn't let smoke escape from a wire at one time or another. If you haven't blown a fuse or made smoke, you haven't done any electrical work. Stuff happens.
Silvertip
Eurolarva, where are you in Minnesota. I hang out in Owatonna (Cabelas is my second home).
eurolarva
Brooklyn Park here. I fished years ago down in Owatanna and accidently caught two nice walleyes. Lucky you on cabelas. We have a nice gander mountian in forest lake I like.
Silvertip
You'll have a Cabelas up that way in the near future (out I-94 towards Rogers as I remember). I moved down here two years ago this month so I'm still trying to figure out the lakes. Most of my real serious fishing is done in Wisconsin (are you there Roscoe???)
