I just bought a bass boat and it has a Guest Battery switch on it. I have one cranking battery and one battery for the trolling motor. I have attached a picture. It basically allow me to choose one battery the other battery or both. Im not sure what it does? Can anyone tell me how I should be using this thing?
Below is the description of the product:
The Guest battery selector switch is designed for universal mounting and features alternator field disconnect. This universal model battery switch carries a rating of 230 Continuous Amps and 345 Momentary Amps.
Dimensions: 5"D x 2-3/4"H
* Alternator field disconnect (AFD) allows selection of any positions, including "off" without damage to alternator or elecrical system. AFD is required on some electrical systems.
* Heavy duty copper sweep contacts
* "Make before break" contacts allow selection of all positions except "off" while engine is running
* Use with 6, 12, 24 or 36 volt systems
* New design is easy to retrofit into existing hole patterns
* Built-in skirt protects connections
* Exclusive flat 360 degree "sweep" contact design provides up to 60% more contact area than other switch designs
* Surface or rear panel mounting
* Marine grade construction
* One year warranty
* One year warranty
