Re: battery switch for dummies
Try this! Think of the two batteries as two buckets of water. Think of the alternator (actually the charging system) as a pump. The pump therefore fills the buckets. In your case, the alternator fills (charges) the batteries. Think of the switch as a valve that lets you select which bucket you want to use to power your stuff. So -- with the switch in the OFF position, the system is dead. You can't start the engine or run any accessories because all electricity is turned off. In the BAT 1 position, you have selected the START battery to run ALL of your accessories, including starting the engine. In the BAT 2 position you have selected the auxiliary or deep cycle battery to power all accessories including starting the engine. In the BOTH position, both batteries are tied together to form one great big battery and again, the two batteries power everyting. OK, we've covered the USE of the electricity. The opposite happens when the engine is running. BAT 1 gets CHARGED (e.g., bucket #1 filled) with the switch in BAT 1, BAT 2 gets charged when the switch is set to BAT 2, and both are charged with the switch in BOTH. Typical use of the switch is to switch to BAT 1 to start the engine. Then switch to BOTH so both batteries are on-line and being charged. When you stop to fish or listen to tunes, switch to BAT 2 so you don't run down the start battery. When you are ready to go you switch to BAT 1, start the engine, then switch back to BOTH and away you go. BUT -- if you have anything wired directly to either of the batteries you are defeating the purpose of the switch. Everything should be connected to the COM (common) terminal on the switch. You can actually start the engine in any switch position except OFF. If you only stop for a few minutes there is really no need to set the switch to any position except BOTH since you would not have run down either battery any significant amount. If you have high power electronics or a trolling motor which are high current draw components, then you do want to "save" the start battery so you are advised to switch to BAT 2 when running those items. You NEVER set the switch to OFF with the engine running as it will immediately fry the regulator. The long and short of this, is that the switch allows you to isolate the start battery so you don't accidentally run it down. It also allows you to switch to BAT 2 for starting if BAT 1 fails for some reason.
