Battery size for Tohatsu 50 hp TLDI
BobGlover
The starting battery on my 50 hp TLDI Tohatsu died after three years and I'm having a hard time finding a replacement. About the largest battery under $200 I can find has a cca rating of 800 and a ca rating of 1000. The manual states that a 850 cca battery is necessary. I read that the difference between a cca and ca test is that the ca is rated at 32 deg. rather than 0 deg. Since I don't run the motor in below freezing weather, will the 800 cca/1000 ca battery work?
TOHATSU GURU
The CCA is necessary to energize the ignition system. The starter will activate with virtually any battery, however, without the CCA the engine will never operate correctly.
