Battery shows 80V when Merc 1500 is running
Zac Penn
The battery shows 12.6V before it starts, then when it is running it reads 80V's.
Any ideas?
Zac Penn
Nevermind. I had my multi-meter on the 200V dc selection which obviously makes a big difference if the motor is running. If you switch the multi-meter to 20V dc then it reads 12.6v off and 14.5v motor running. I wonder whyt he multi-meter reads so high when the motor is running on the 200v selection?
Either way is 14.5v at idle too much juice?
Chris1956
That system is unregulated, but bounded by the absorption of the battery. If you read AC voltage, the rectifier may be bad. If only DC voltage, it may be OK.
emckelvy
Sounds like your meter has a problem. It shouldn't change that drastically in value when switched upscale.
Fortunately, digital VOM's are really inexpensive nowadays, and an under-$20-on-sale-at-Sears meter should give you years of good service.........ed
