Battery Selector switch
mgmmojica
When the battery selector switch is turned to #1, the starter acts like it isn't getting enough power and just makes the clicking noise. The battery isn't dead though. If I take this battery and connect it to switch #2, the engine kicks over immediately . I replaced the battery cables for battery #1 but that didn't make any difference. My battery selector switch (Guest) was manufactured in 1997, so, it could be bad, but in taking it apart, I didn't see any corrosion on the copper plates or the selector plate. I may replace it anyway, but don 't have confidence that this is the issue. Any thoughts as to what might be going on here?
Thank you
MRS
You sure the battery is good how old is it?
mgmmojica
Yes. Battery is a brand new Odyssee with 1150 cranking amps. Tried other batteries at #1 position - same thing....starter makes the clicking noise. When transferring them to battery 2 position - all started the engine. There is something preventing full voltage going to the starter on battery 1 postion
MRS
If you changed cables and cleaned all your grounds could possible be the switch. Is this a new boat to you or it has worked good and just started with this problem?
dingbat
When you replaced battery 1 cable(s) did you replace #1 ground cable as well?
If so, you’ve eliminated everything but the switch.
mgmmojica
This is a new boat to me. 1997 Trophy 2352. Haven't had it in the water yet. Just finished having the outdrive rebuilt. Would have had them check on the battery 1 problem but thought it would just need new cables.
mgmmojica
No. Didn't replace the #1 ground cable. Hoping I don't have to as it is buried in a bundle of other cables and haven't traced out where it goes yet. But, if corroded, that could be the culprit.
Thanks
