Re: battery reboot
If you decide to try the "battery restorer" let us know how it goes - meanwhile, here's a site with more than the average bear needs to know about batteries ...
http://www.uuhome.de/william.darden/ ...<br /><br />Besides the voltage, you also need to check the individual cells with a hydrometer. Too much variance between the charge in the cells is a warning sign of impending failure. I wouldn't advise getting the cheapest hydrometer.<br /><br />Interestingly, I spilled a bit of acid (cheap %!&$ing hydrometer) from my cranking battery - just a little bit, maybe 4-5 tablespoons - replaced it with water, and it was showing those symptoms you described (more rapid than normal self-discharge). But after a half-dozen discharge/recharge cycles, it's almost back to normal. Lately I've been charging it every few days at 2 amps for 5 or 8 hours, whereas I used to charge it for a few minutes at 15 amps once every couple weeks (I fish every other weekend). This is also a 3-year-old battery, and the hydrometer test shows all cells with about the same state-of-charge.<br /><br />good luck,<br />jtw
