Re: Battery question
Prior to starting the engine, turn the battery switch to the BOTH (ALL on some switches) position so that you have the full cranking power of the batteries. Once the engine started, leave the switch in the BOTH position while powering to the day's destination so that both batteries are charged. <br /><br />Once a powerboat dropped the hook, you then turn the battery switch to the 1 or 2 position, so that the other battery would be reserved for starting. <br /><br />When it is time to crank the engine again, the battery switch should be turned to BOTH, or possibly to the reserved battery, and the engine would be started. <br /><br />The problem, of course, is that this requires a lot of thought on the part of the operator, who is trying to relax in the first place. The inevitable result is that at some point, the boater accidentally leaves the battery switch in the BOTH position, resulting in two very dead batteries. That is why you should install a battery combiner like the West Marine Combiner 150. It does all of this automatically.
