MikesBayliner
- Nov 14, 2017
- 14
I bought a Bayliner last fall and winterized it correctly and kept it on a battery maintainer during the winter. This past weekend I pulled the boat out and tried to start the boat. Nothing but clicks at the solenoid and the starter would not turn over. I tried jumping the boat and eventually the boat cranked and ran fine. Took it out and spent several hours getting to know the boat. The next day I went to clean it up and tried to start the boat, but again, just clicks at the solenoid. I didn't have my multimeter with me to check the battery but feel that the battery won't hold a charge. What I don't understand is that with the key in the off position, all of the controls (and horn) will still work. That's my question: With the key off should any power be "on" at the dash? Please let me know. If anyone else has any other ideas on what would be a battery drain would be helpful. One last thing: I noticed in the bilge area this past winter when I was wintering the boat a short 8-10" insulated wire with alligator clips on each end. Could this have been used to jump a bad section of wire between the battery and solenoid/starter? Not sure it's related to my problem, but found it strange thinking I knocked it off during the winter maintenance.
Any help would be appreciated. Thank you.
