Battery only holds half charge?
ebsworj
I have a Exide dual purpose battery that came with my boat. When I charge it with my fancy charger that displays the % of charge and volts etc. It gets full then the next day it will only read 65% charged even though its just bee sitting in my basement.<br /><br />When we run it in the boat with a 200w stereo and amplifier 180w it will start to cut out after about 30 mins and the volume will have to be turned down. <br /><br />Do I need a new battery or is there anything I can do to help this one out?<br /><br />BTW I did get all the wires to have a dual battery system this year with a switch.<br /><br />THanks
LubeDude
Re: Battery only holds half charge?
Originally posted by ebsworj:<br /><br />Do I need a new battery or is there anything I can do to help this one out?<br /><br /><br />
:p :p :p I think you know the answer to your question! :rolleyes: :rolleyes: :rolleyes:
Silvertip
Honorary Supreme Mariner
Let's see - we have a high power music system operating on a battery that loses 35% of its charge doing nothing. You need the largest deep cycle battery you have room for -- just for the music system and accessories. Use a marine starting battery for the engine. Or buy the largest marine dual purpose battery you have room for and a jump start pack just in case you do tunes longer than you think and the engine now has no juice to draw from.
ebsworj
ok ok, guess i knew the answer but wanted some magical solution from you guys.<br /><br />thanks
