Battery hook up
rsyates
Just got an electric start, 2000, for my sailboat. The motor is setup with two wires that connect to the battery. Wish to use two batteries with a 4 way switch. What do you think.
petryshyn
Re: Battery hook up
Hi....Done lots of battery work over the years.Maybe I can help.Not sure what you mean by a 4-way switch.Please explain.you probably should also post this topic in the 'engines+motors'
rsyates
Re: Battery hook up
I'm referring to a Batt 1, Batt 2, On, Off swithch...Thanks RC
petryshyn
Re: Battery hook up
You also might consider using a 'Delco maintenance free' battery which is less likely to leak electrolyte when the sailboat is on her side.
