Battery Ground
D Man55
I just bought a 1988 VIP with a 4.3L V6 GM engine. The battery is grounded to the starter case. Is this correct?
Don S
Re: Battery Ground
No, the main battery ground is typically connected on one of the bolts holding the flywheel cover to the engine block.
JB
Re: Battery Ground
Howdy, D Man.
Welcome to iboats. :)
As long as the starter case is grounded to the engine block that should work. It is more usual to ground the battery cable to the engine block, as Don points out, but the starter case needs to be at ground, too, for the starter to work.
Silvertip
Honorary Supreme Mariner
Re: Battery Ground
The only issue I see with the ground cable attached to the starter case is what bolt was used?? Unless it was one of the starter-to-block mounting bolts I feel any of the remaining fasteners are too small for a good connection.
Don S
Re: Battery Ground
The main starter mounting bolts are also special starter boats, and you don't need something under them that could allow the bolt to loosen.
D Man55
Re: Battery Ground
Thanks Don, I sanded the rust and paint off an engine mount and moved the ground to it. The starter still turns a little slower than I think it should. I probably need to replace it or have it rebuilt.
