Hi to all. I have a 2008 50hp tlr 2 stroke yamaha outboard. I have a problem that if I leave the battery to the motor hooked up the battery dies. I took the boat back to the dealer last year and watched them hook it up and test it and there is no draw on the battery from the motor. I have only the starting battery hooked to the motor. All other electronics are tied to 2 other batteries. If I disconnect the negative cable of the motor from the battery, no problem. Battery stays fully charged.
I have a hard time believing that everyone with a yamaha has to disconnect a cable to keep battery from dying. Any insight on this problem? This last one makes me mad cause I used the boat on tues, didn't disconnect the battery, and fri. it was dead. I also had the dealer check the charging system of the motor and it was operating perfect.
Thank you.
Thank you.
