Re: battery drained is it dangerous to boost with another Battery in the Boat
When it is cold out, I don't even bother trying to start my motor on one battery. I hook jumpers from my trolling battery to my starting battery, and it fires right up. Optimally, having a 2 battery switch is the way to go, so you can place it on BOTH to start, then you can place it on 1 or 2 to charge (you don't want to try to charge both at the same time). One of these days I'll install one of these switches, but for now the jumpers are great (when it is 30 degrees, obviously don't need them when warm). You also really should find out why you had to crank that motor so much to drain the battery in the first place.
