First off, I did a bunch of searching around on here and couldn't find anything related to a battery switch. I found that taking the negative battery cable off, or positive, and putting a multimeter on it will help determine some sort of battery drain. I have a 2 battery setup with selector switch for each one. Battery one has zero drain. However battery two shows up with having a leak to the tune of 11 volts. There is only a bilge hooked up to that battery and if I disconnect the bilge, it still shows up. Any thoughts on what it could be?
2000 cobalt 246.
thanks for your help.
Dave
2000 cobalt 246.
Dave
