My friend has a sailboat with an electrical switch and he asked me to help with the connections. We are both new to this... The switch has three connections, and four positions. Off, 1, 2, 1&2. <br /><br />I am thinking that it will be for batteries, and disconnects. The boat is a 24 foot sailboat, and has presently only one deep discharge battery onboard. He has a Nissan electric start 8 HP (I think 8) that can also charge the battery. The electric start pushbutton is built into the motor, so I imagine the battery power to start, and the battery charging power from the motor generator come through the same heavy duty wire. (What size wire should it be?)<br /><br />Shore power presently is separated from the batteries, and is only connected if a battery charger is plugged into a 110 plug.<br /><br />With only one battery, how should the disconnect switch be wired? With two batteries, how should it be wired?<br /><br />I am the electrician, so I understand the process, but am not sure how it needs to be hooked up. <br /><br />Thanks so much, Mike
