Battery Combiner for each motor?
SATCHER
I have twin 90hp Evinrudes (with 20 amp regulated charging systems)on Glacier Bay Cat. One battery and gas tank for each motor. Completely seperate electrical systems. I installed a third house battery to run lights, live well pump, & accessories.I installed a 50 amp West Marine battery combiner to port engine battery.It does not seem to be able to keep house battery charged. Can I install a second combiner from starboard engine to help in charging the house battery? <br /> <br /> Thanks Gents
18rabbit
Re: Battery Combiner for each motor?
The battery combiner from the second charging source can shut down its attempt to charge the house battery when it senses the higher-than-battery voltage coming in from the first combiner’s charging voltage. Normally, two independent smart charging sources on one battery do not always work unless you are combining the outputs of a single dual-bank charger that is designed to sense the combined outputs.<br /><br />A simple solution would be to install a deep cycle house battery that is big enough to provide the amp hours you will need during a typical boating session then re-charge it using a 120vac charger when you return. In your case it may be as simple as adding a second, identical house battery in parallel and an appropriate battery charger. You can leave the battery combiner on there, it doesn’t hurt anything.<br /><br />Alternatively, you can toss one of the new AGM deep cycle batteries into your boat for a house battery. They can accept a charging rate of C/1 … capacity-over-1 … that means a 120A/Hr battery can be charged at a rate of 120amps. You would think the battery could be completely recharged in 1-hr but the battery resists the charging voltage as it ‘fills up’. It takes about 1-hr and 15-mins to completely charge a complete flat battery. Depending on your alternator’s output, you may need to install a bigger, beefier alternator to keep up with the battery.<br /><br />There is a guy in Fort Lauderdale, Florida that can help you with what you are trying to do. Call Meridian Marine at (954) 761-3940. Ask for Harrison.
SATCHER
Thanks Rabbit<br /> All three batteries on the boat are AGM deep cycle. I have an on board three bank battery charger/maintainer which tops off the batteries nicely overnight. If I add a second house battery in parallel, do you think the on board charger will still work? Thanks for the contact in Lauderdale.<br /> <br /> JD
