Re: battery charging on the water
BTW, You can install a volt meter instead of an ammeter guage. The volt meter guage will indicate the battery voltage when the motor is off (12.5) and will indicate the alternator voltage when the motor is on (14). Does the same as SoLittle's voltage check, but it is always hooked up. And it doesn't need all the big guage wire that an ammeter needs.<br /><br />One drawback to the ammeter guage is that all current (except for the starter motor) will be going through it. If the guage is mounted on the dash, and the motor and battery are in the aft, then you need to run a lot of large guage wire from the motor to the dash then back again to the motor. This can cause a voltage drop if the wire is not large enough to carry the boats load. If you mount the guage near the motor, you bypass this condition, but the guage is not easy to read from the helm. <br /><br />Mark
