Battery Charger, does my boat have one?
PanchoCC
Electrical Panel has switch/breaker labeled "rectifier". Is this the charger ?
I know a rectifier converts 120-AC to 12v-DC, but I have also seen battery chargers on the internet which are called "rectifier / chargers". So I want to know how to determine if the "rectifier" switch/breaker is also for a charger, and if so, then should I have that switch on when I plug the boat into dock power?
Boat didn't start today. Both battery, new 60 days ago, were low, at approx 8 volts each.
If boat does not have charger, then intend to install Promariner 20 Plus, 3 bank charger.
Need to know if boat has a charger.
Thanks
1985 Chriscraft 337 Commander, aft berth, twin 454 Merc. IB's
Windykid
Re: Battery Charger, does my boat have one?
Does the boat have a seperate generator?
You could always just plug the boat into shore power and try the rectifier switch and see if it charges.
Do the battery's have the extra wires?
PanchoCC
Yep, boat has seperate genset.
Rectifier charges on motor battery only.
Boat has 3 batteries--2 for twin 454's, and one for genset.
