Re: battery cable length, how long?
You have not provided enough info to get really specific about an appropriate battery cable size. Here is the general guideline.<br /><br />0 3.5ft use size AWG 4 wire.<br />3.5 6ft use AWG 2 wire.<br />6 7.5ft use AWG 1 wire.<br />7.5 - 9.5ft use AWG 0 cable.<br />9.5 - 12ft use AWG 00 (a.k.a. 2/0)<br />12 - 15ft use AWG 000 (3/0)<br />15 19ft use AWG 0000 (4/0)<br /><br />Presuming this cable is for starting your engine, bigger cable is better. You want to minimize the voltage drop through that cable. Typical starting systems have a .2v drop, add to that a 3% drop in the battery cable (.36v for a 12v system) and you are down .56v before you even get started. Bigger is better in this case. You should be ok with 3/0 but 4/0 would be a better choice. Either way, you are going to have some big, expensive cables stretched across your deck.
