Re: Batteries?
Lynn<br />Both ways have advantages. One large battery will be cheaper than two. Also you do not have charging and switch issues.<br />Two batteries with a switch adds some relibality. Two batteries work very well but I do not recommend just putting them in paralell. If you go with two then wire one for every thing that came with boat, Motor, Lights, Bilge blower, Bilge Pump, Horn. Wire the second for all the add on stuff, Raido, Gps, Fishfinder, Radar, ect.<br />Too charge two batteries I would suggest a batery isolator, that way if one batteries has a problem it will not run down the other. You can also add a battery switch so if main starting battery is dead can switch to back up. If you get a switch get one that has a field disconnect so that if you turn it with engine running will not blow up your alternator.<br />A little more info would help. Why do you fell you need more battery power?? Do you have a trolling motor in use?? What is the output of your alternator??
