I know this has been covered before, but where is the best location for this transom mount transducer on a fiberglass bass boat? It's a Lowrance skimmer type.
I can't really take it out and run it looking for a low turbulence area since I have 1 tube of 4200 to seal up under the rub rail, screw holes, etc and this transducer all in one shot. I'm looking at the starboard side where the PO had screw holes for a transducer, closer to the side of the boat, but behind a flat place on the hull. Is this the best place or would it be better to keep it closer to the center, but at least 12-in away from the outboard, where it would be deeper in the water?
The first pic shows the starboard side that I'm considering. The 2nd pic shows the port side with a built in area below the hook, recessed under the transom about 2-in that looks like it has a purpose?? Does anyone know what this might be for?
Thanks for your help!
http://i84.photobucket.com/albums/k39/bailey12_06/2005 Stratos Boat/072610_Stratos007.jpg
http://i84.photobucket.com/albums/k39/bailey12_06/2005 Stratos Boat/072610_Stratos005.jpg
