dr.livingston
- Nov 5, 2008
- 60
I just bought a used boat with a Force 120 on it. The previous owner apparently did some midnight engineering on it and so I have some questions about restoring full functionality.
Originally it apparently had two batteries and a manual selector switch. He removed one battery and the selector switch and moved the other battery to make room for more fuel tanks.
Question 1. Is the second battery simply a spare in case the first one dies, or is the second battery a "house" battery that runs lights and accessories while the first battery cranks the engine?
Question 2. Does the engine charge these batteries while running, or do I have to use a separate charger to keep them up?
Question 3. Neither the tach nor the speed gauge works although the volt meter does work when I turn the ignition key. Did he disable them by removing that second battery? He also removed the fish finder and the marine radio so maybe he left the gauges disconnected while he was fooling around behind the instrument panel.
