Basic Battery Question
BoatBuoy
I will be buying a new starting battery soon and I have a very basic question. Are they fully charged when new, even though they may have been sitting on the store shelf for several weeks, or should they be "topped off" with a trickle charger?
18rabbit
Re: Basic Battery Question
I don’t charge a new car battery before using it but I do for a new boat battery. I guess the preference is to charge it before using, but I think it is probably more important to know the battery can hold charge.
levittownnick
I'm reasonably sure that a new battery does NOT come with a full charge. For general automotive use, this is not critical as long as the battery has sufficient charge to start the car. Outboards usually have a much smaller charging capacity than cars and a limited charge could have a greater impact on the water. I would start with a full charge---but don't overcharge.
Boatist
Battery is fully charged as soon as they add the battery acid. The chemical reaction starts. On the shelf it will self discharge like any other battery so good idea to charge. It can be charged by a good automatic battery charger or your boat's alternator if you are going to run a good distance. To reach a full charge takes some time so I think better to charge with a good automatic battery charger. I do not like trickle charger as most have no voltage regulation so can over charge. If it really needs charging it takes forever. Now a battery maintainer, a form of a trickle charger with voltage regulation is a good way to top off a battery and keep it charged.
Sea Six
Your battery will be fully charged when you buy it, depending on how long it sat on the shelf. Look for a sticker on the side that indicates the manufacture date. It should say A5 or B5. The first alpha character is the month (A=January, B=Feb, etc) and the number 5 is the year. Look at the batteries on the shelf just like you buy milk - the new ones are in the back!
SeaHorse
Unless the store where you are buying it periodically charges the batteries, it will not be fully charged when you buy it. When batteries are made, they are filled with acid and then they need to cool off and then are charged. A few hours after a battery is filled, it will only have about a 65% charge state. It is always better to charge a battery slowly. Slowly means no more than 10% of the battery's rated capacity in amp hours. If you have a 60 amp hour battery you should charge it with no more than 6 amps. To figure the charge time needed, divide half the charge amps into the rated capacity, in this case = 20 hours. Battery makers have specific charge recommendations for each battery type. <br /> <br />A conventional lead/acid battery will discharge about 1 to 6 percent a week depending on the temperature. So, if your battery has been sitting inside a hot boat store since last September, it will be quite discharged and will need a charge. This is not a battery I would want to buy. Take a voltmeter to the store and don't buy a conventional battery showing less than 12.4 volts. <br />Most "trickle" chargers (less than 1 amp output) won't charge a big battery fast enough (overnight) for normal use. Most inexpensive chargers made for cars (6 to 10 amp) will not overcharge your battery providing you leave them on just overnight. More sophisticated chargers can be left attached all the time. <br />Remember, a charging battery is a hydrogen gas factory--avoid flame or spark and wear face/eye protection if your face is near it.
PJSuburby
My local Costco has NEVER had a decently charged battery, so I look elsewhere for good boat batteries
Sea Six
If you find 2 batteries on the shelf, one with an F4 sticker on its side, and the other with a B5 sticker, which one will you buy? One will be at least 90% charged, the other won't!
