Boomyal
Thread starter- Joined
- Aug 16, 2003
- 12,072
Can/do these ever go bad to the extent that they begin to pass full voltage? I assume that most older point/condensor powered autos had them?<br /><br />My '65 Mustang Manual says that there is one and that seems consistant with the way the positive lead to the coil was run. It came out of a wiring loom direct to the coil. The manual showed that the tie in from the full voltage supply from the starter solenoid occured further back in the loom.<br /><br /><br />Pertronix recommends that you bypass any ballast to give full voltage to the coil. So once the system was hooked up and running I checked the voltage at the coil and it was a full 12.5 +-.<br /><br />What would have been the symptoms if the points had been getting full voltage all along?
