Re: Ballast Resistor, do I have one?
Let me ask you this 1 question. Is a transformer a resistive load or an inductive load? Which type of load is a transformer?
It is Both. The windings have both a resistance and an inductance.
When you think the word "Transformer" The common Power Converting Transformer is what comes to mind.
It will have more than enough Iron in the core and enough permeability that the core will never saturate at the frequency it is design for.
The Inductance in the common Transformer, under normal operating condition, is the dominating factor.
The resistance is still there but can normally be ignored.
This is an important consideration when you attempt to operate equipment designed for 60hz, on 50hz power mains.
The 60hz cores may saturate and the transformer primaries will over current and overheat.
The Ignition/Spark coil is a low permeability transformer and is operating on DC not AC.
The points close, the Inductance in the core limits the current Just like a normal transformer until the core reaches saturation.
The current then becomes steady state DC and is limited only by the Resistance in the windings.
The points Open, The collapsing magnetic field attempts to keep the current flowing and charges the capacitor.
Once the Cap reaches max charge, the current reverses and the spark happens.
This is NOT a simple AC transformer circuit.
Look at the link in Post #16 again.
