Re: bait caster
stl, use 12 to 14lb test line for best results.<br />As stated above, put on a 3/8oz weight of some kind, I use spinnerbaits, and hold the rod at about 45* and push the button and let weight fall to floor.<br />If it stops before you get there, it's to tight.<br />If the spool keeps running after it hits, too loose.<br /><br />You should have, but not always, 2 adjustments on it.<br />One will be by the handle and that is for manual brakes. This is the one you set to get the weight adjusted right.<br /><br />On the other side of the reel should be but not always, another adjustment. This is the one that really helps when casting.<br /><br />It's a trial and error thing cause everyone throws them different.<br /><br />I prefer the sidearm cast. Just got use to doing it because of the wind and found out I like to do it all the time, plus it's good for getting under trees and docks that way.<br /><br />BTW, the rod will play a lot into all this also.<br /><br />Guess that's the reason my rod locker is full.<br /><br />Different rods for different things.<br /><br />Good luck and keep at it, you will get it right.
