Baffled
Jess s
I have a 1993 johnson 200 hp. V6. I,m having low water pressure to the head. I overhauled the lower unit and I may have damaged the water tube. I have the lower unit off and trying to find the problem. I,m trying to remove the mid section to see if that,s it. How does the water tube fit into the upper section? Is it a press fit into a grommet?
How many bolts hold the mid section on? I,ve removed 9 and it won,t come off.
