Hi All
I just replaced rectifier/ reg. The tach still will not work off the gray wire. ( it drops below zero) However it does work off the yellow/ gray one. The boat runs fine. Battery seems to to be charging. It hasn't gotten weak seems stronger. Turns motor very quick, easily starts. What could it be. The old r/r I think shorted out when the red wire chaffed and grounded on the stater solenoid. Would the solenoid be bad and cause the tach not work. But if the solenoid was bad would the starter work???
pls help me to understand
MRD
MRD
