dragula65000
- Apr 14, 2004
- 180
On start up, the motor shakes real bad, spits spuders and shuts off. There is quite a bit of oil out the bottom of the prop. When the motor is trimmed up, oil comes out thru the bottom of the carbs. Does it also pump fuel as well?? I replaced the primer bulb and added a clear fuel filter. I read all the posts on testing for oil output. Are there any tests to see if it is getting fuel? Also, I pulled the plugs and there is oil on them.
