Bad to Worse with my Merc. Any of you mind walking me through replacing the pump
boltonranger
Hi fellas.<br />I posted yesterday with an idle problem...<br />I probably should have explained that the motor does idle well when warm for a period of time and then acts like it's loading up.<br /><br />Anyway... I went home and set the timing proper and the dwell. The timing was out by 3-4 degrees. Then I adjusted the idle with my tach. I got it where it starts with about one crank.<br /><br />BUT. I didn't realize my water hose (from the house) was on a timer. I ran out and ruined my pump. The motor did not overheat thankfully but I was kicking myself over that pump.<br /><br />I don't have the service manual; but see where 6 bolts hold the lower unit on. I'm guessing this is where to begin. Would any of you mind walking me through replacing that pump?<br />-thanks. -br
DustyJacket
Re: Bad to Worse with my Merc. Any of you mind walking me through replacing the
There is a site on the web that walks you through it. Let me search...<br /><br /> http://www.i-boats.com/wtar_pump_repair.htm <br />or<br /> http://www.brokeboats.com/newpump.html <br />or<br /> http://amarket.com/f091.htm <br /><br />There is a better site with drawings and photos, but I cannot find it. I think the bookmark is at home.
BMDODGE
here's another good site web page<br />Welcome Aboard - Bruce
boltonranger
Thank you boys.<br />The links were what I needed.<br />Took it apart last nite.<br />Should be up and cruising this weekend.<br />Again; many thanks. -br
