Re: bad tire wear
If by inside wear you mean the side facing the keel, and outside wear you mean the side facing the hub, then I don't think tire pressure would be the problem. That is, indeed, a very strange situation. 3 possibilities come to mind:<br /><br />1. Have you owned these tires since they were new? If no, then you really have no idea how they are wearing. They may have been 2 used tires off the left side of an overloaded tandem, for instance. That would explain the one-sided wear. And now they need to be replaced anyway, so start over and see how the new ones start to wear, if at all. Also...are both tires the same size and brand/model? If they're a mismatch, this would easily cause the prob.<br /><br />2. A broken spring or excessive weight on the side with the outside wear. Is the boat sitting level and centered? If all the weight is on one side, I can see this possibly happening.<br /><br />3. Bent axle, or axle not mounted square to the frame. Confirm mounting squareness with a tapemeasure and two angular measurements...one from the left rear corner of the trailer frame to the right side of the exle, another from the right rear corner of the trailer frame to the same spot on the let side of the axle. I'd say any variation of more than about 1/4 inch from one side to the other needs adjustment.<br /><br />These are just ideas....that's an odd one. I'm really leaning toward #1, but only you can tell us whether you've owned these tires since new. Good luck!
