hello,<br />I have a 90hp jhonson, and Im having problems starting it. The bendix gets stuck up in the flyweel, and also it turns very slow. The problem is getting worse and worse everytime. It all started when my old starter went bad and when I replaced it I had a little bit of trouble getting it installed because of the same problem it got stucked in the flyweel I adjusted and it worked fine for a cuple of months and then the same problem started to apear again. Someone told me that it could be the battery cable, so I replaced the cable and the problem still the same, I charged my battery and nothing. I´ve tried with different batteries to make sure is not my battery.<br />So what do you think?? In my opinion I think I bought a defected starter since the begining. Or could it be the solenoid?? I also jumped directly from the battery to the starter to eliminate the solenoid, but still the same problem.<br />Please help me out here, I would appreciate it very much.<br /><br />Thank you
