I have a 89' 75Hp mariner with a an oil injector system.Today the "low oil alarm" went off and never stopped. When I checked the oil level, the oil reservoir was full. I am thinking the sensor inside the reservoir is bad and I will have too replace the reservoir (the sensor is built into the reservoir). Is there anything else that would cause this problem that I should check before I replace the reservoir?<br />Thanks in advance
