Re: Bad Cylinder
I will respectfully disagree with Roberts estimate. I have done 2 115s over the years out of the same necessity you speak of. I don't have a lot of money. Neither of the ones I rebuilt cost me more than $900. The first one was in the mid to late 90s and I replaced everything, all new pistons, rods, rings, bearnigs (except the upper main bearing which is an expensive part that I was told seldom fails), seals, and gaskets I had all 4 cylinders bored 30 thousanths over...Cost right at $900. The second one I bought a 2 year old boat with a bad cylinder for almost nothing. Since the motor was only 2 years old I opted not to replace the rods and upper & lower bearings the cost was between $600 & $700.
I am fixing to do my third one, which is actually a redo of my 2nd one. This time I am hopeing to reuse even more of the old parts I still expect to spend around $600 dollars maybe more or less depending on the advice I get from the experts here. I am fixing to post a few questions, since we have the same power head you might want to check in on my thread when I start it.
Once again with all due respect to Robert I really don't see how the parts can run you near that high unless you wind up replacing the crankshaft which would drive the cost even higher.
