I have a Mercury 90 hp outboard 6cyl. inline believe early 80s sn# 06399494<br />THe problem is the engine runs fine but prop will not turn in forward or reverse. It quit working as I was accelerating and now no longer turns at all.<br />I have determined by removing the bottom half of engine that drive shaft turns prop just fine but the engine does not turn drive shaft. I pulled power head reached my finger inside end cap and can feel no splines inside the power head. (the splines on drive shaft seem fine)<br />I am told that the drive shaft connects directly into the crank shaft which has splines on the inside of one end. Is this correct or does the end cap connect the 2? What are my options since if it is the crank they are no longer available?
