bad coupler?
bigskiohio
Master Chief Petty Officer
I think mines bad boat wont go and people by the back said they smelled rubber
shifter engages with little effort but prop ratchets when in the right position. Also when i crank engine get squeal noise. Will rotate engine and see if shaft turns. 1973 120 mercruiser ran great but treating it like a jet ski while tubing is a no no. what a idiot i know . Probably needed outdrive removed and serviced anyways. will work on it as soon as it warms up in nw ohio. Hope i diddnt hurt outdrive. does the sqealing when cranking sound familiar?
ezmobee
Re: bad coupler?
You be better off posting this in the i/o engine forum.
bigskiohio
Re: bad coupler?
Its a starcraft 1973 ss and this is starcraft group so there should be some answers and experience her.
