Re: Bad/Broken kill switch wire from coil. Can it be replaced?
Thanks for the input everyody. So I went and got 30 ft. of 14 gauge wire to replace my old, black kill switch wires in the photo. It worked great and was easier than I thought. I installed an emergency kill switch while I was at it. However, there was one strange thing. When I hooked the new dead man's switch I ran wires from the points to the "M" terminals on the switch (b/c I have a magneto ignition). Howevr, the motor would not start with the lanyard in place. When I removed the lanyard, she would start with ease; backwards from what it should be, right? I then switched the wires and put them on the "C" terminals and the switch worked perfectly. When I pull the lanyard and the motor dies and/or I can push the red button while the lanyard is still in place and shut off the motor. Why does the switch work backwards when it is hooked up "correctly" on the "M" terminals, but work correctly when hooked up "bakwards" on the "C" terminals? Either way it works great now, I'm just kind of curious.
I'm gonna switch the s'plug wires too per Xcuseme's suggestion. I just wanted to do one electrical job at a time. It's not my specialty, but I'm starting to get the hang of it. Thanks everybody.
