optimax1999
- Jun 24, 2013
- 6
I have a new to me boat, in a new to me marina. The river this is on has an extremely strong current, and is well known for such (especially in this moon cycle). The current is strong enough that when navigating down the asile of finger slips, the boat needs to be crabbed at about a 45 degree angle to the aisle facing into the current just to make headway parallel to the aisle.
My boat is pulled into the finger slip bow first. When the it is an outgoing tide (current pushing against the stern), and I back out of the slip and turn the boat, the current pushes the stern back towards the dock. This will happen fast enough that there is not enough time to turn the bow starboard before it gets too close to the dock. Also, turning starboard (to get away from the dock) is my natural instinct, but it also enhances the stern's port swing towards the dock/other boats. There is also not enough space between rows to allow me to back far enough away from the dock before making my turn to compensate for the drift that the current will cause.
Now, obviously if the boat is backed into the finger slip during an ebb tide, the whole problem would be solved. However, on the incoming tide I would have the same situation, just reversed. IF the boat was backed in, on an incoming tide I would need to make an 'almost' 180 degree turn to get the bow facing in the current so I can crab it out of the aisle. I just don't think that would be feasible given the limited space I have to work with.
The only option I can think of for this situation is to back the boat out of the slip, and then crab it all the way down the aisle with the sten facing into the current. However, I'm not confident in the boat's reverse handling capabilities enough to perform that maneuver quite yet (I will have to get out during a strong current and test its reverse capabilities against a buoy as a marker). It seems to be weak in reverse and requires quite a bit of throttle to make any headway in reverse.
To aid in understanding my perspective, I'm not green to boating, or this river/current, and this is not my first boat. However, I am new to the propulsion system (coming from much more responsive jet drive, to currently a single outboard). Boat is 23' LOA, with single outboard. This seems like it should be a very simple issue (or maybe not an issue at all), but for some reason I cannot see an easy way around it. Maybe I'm just missing something obvious here that someone will point out.
I've attached a very basic diagram of the situation for anyone willing to give me input to reference.
Thanks for the help, and I look forward to becoming a contributor instead of a lurker on this forum!
Should also note that I have no issues at all docking the boat during either tide, or backing out of the slip during an incoming tide.
